Who cares about an unmounted tire? Mounting is what ruins a good tire if you put it on a wheel that's the wrong size.
I'll use a gross example to kinda drive this point home. Assume for a moment you could physically mount a 275 on a bicycle rim. To get it to fit, you'd have to pinch the tire flat and it would cause the tire to balloon outwards. Your contact patch would then be a sliver of its original width. It would basically look like a wobbly wagon wheel. All that tread that should be on the contact patch rolls up into the sidewall. In this example, it wouldn't hold the car's weight due to there being no rigid sidewall to help the tire maintain form.
This same effect occurs when mounting a 275 to a 9" wide or smaller wheel. Tread rolls up to match the wheel width and a portion of the rolled up tread is taken up into the sidewall, compromising the tire's strength. While it will still safely mount and be a safe tire to drive on, it no longer has a 275 expected contact patch. It's a 235-245. That soft tread you're not using is rolled up into the sidewall and making it less rigid. This causes a degree of lateral skating at launch, more wheel hop, and reduced lateral grip load rating.
Folks can either accept this as fact, or they can try and come here and explain why their car is the only magic fantasy car on the planet that is blessed with the uncanny ability to ignore the laws of physics.
