Ran over a branch/log: what to look for
17K views 9 replies 8 participants last post by  Hal H
On my way back from Lowe's today: doing 60 in a 60, traffic in front and behind. Was following a box truck at my usual ~10 or so car lengths when I see what looked like a little mound of spanish moss laying in the road. Well, apparently there was something solid inside that moss because when I ran over it, I heard two distinct THUMPS. The first was a little louder than the second, like a THUMP-thud. No time to avoid it as traffic was coming the other way and because we were all forced to do the speed limit, of course someone was riding my ass so I couldn't really slow down. Just had to run over it. I don't know if it kicked it up after I ran over it but the woman riding my ass dropped WAY back after I ran over it.
My luck: my dashcam had just fallen off the windshield while I was in Lowe's. Was extra warm today and the suction cup let go, so I just put it in the glove box until I could clean the windshield when I got home and put it back on... else I'd have it on video.
My question: it's raining now but I managed to get underneath it enough without the ramps to look around and I don't see any damage. What should I look for as far as damage? I'm thinking maybe dented exhaust or look for wood debris on other areas that stick down the lowest? As of now, I don't feel/see anything abnormal but those thuds were pretty darn loud: hard hits. Figured it might have happened to someone here and I might get a "better check this" reply. The thing I find odd is that you'd think it'd hit the front lip spoiler first... but there's not a mark on it. I suppose the moss could have caught on something else underneath though and kicked it up?
Thanks,
Mike
#2 ·
What you want to look for is more in the "feel" of the ride. You're looking for any unusual motions from the rear end or swaying motions from the front or rear. Stand behind the car and look for any graphic wheel angles "out" or "in" at the top. One last thing is to watch for any unusual tire wear. Anything funny in the usual feel of the ride and I'd just get it in for an alignment check. Good Luck :thumbsup:
#3 ·
Two thumps should mean your tires went over it, I'd look at the rims inside and out for any bends, does the car shimmy at all?
Look at the air dam and the belly pan. Hopefully all is,well and your lucky on this. Most importantly is you're fine. Good luck.
#4 ·
Thanks guys. Gonna give it a good once over when the rain stops tomorrow. It felt fine but I was close to home and still a bit "puckered" from the incident so I didn't think to check steering/alignment on a straight. I'll do that tomorrow. I don't think the tires went over it though. It was at most, 18 inches wide and it went smack under the center of the car. I didn't feel anything through the steering wheel and it didn't feel like the suspension moved as it would if the tires ran over it. It felt more like two metallic thuds, like the first one hitting the lower crossmember and the second one hitting more toward the rear, like possibly the rear axle housing. That's what I "imagined" in my mind anyway because it felt like it hit two things that were pretty solid: no clanging or tinny sounds. Just thud-thup. I'll get it up on ramps, drive it, eyeball the things suggested, and report back tomorrow.
Mike
#6 ·
When you get it up on ramps, check carefully with a bright light and look for dents in the lower "frame" structure, the K member, and for damage (cracks or leaks) around the rear axle. In addition, check the plastic bits for cracks. I wouldn't worry about a minor dent or scrape here or there. If it's only a dent on the exhaust system, it should be okay.
Good luck.
#7 ·
Nothing to really add that hasn't already been covered, but if it makes you feel better i hit a ~2-3 foot twisted piece of sheet metal that for some reason was in the middle of the interstate the other day. Just sort of came out of nowhere and made quite the ruckus as i ran it over. When i stopped i immediately checked for damage and thankfully it hit the front license place plastic mounting assembly. Cracked that sumbich right down the middle and bent my front plate up with an additional few scrapes on the front chin spoiler. I was going to get my catless mids installed so once my buddy and i got her up on the lift i was able to do a further inspection and make sure there was no additional damage. It's a damm jungle out there on the road i tell ya. Glad to hear you and the car (so far) are okay.
#8 ·
When I had my 98 1500, I was driving on the interstate going 75 and some dudes tire came off their car and rolled into my lane. The tire was still rolling foward, probably like 50mph or so, when smacked it doing 75. I was on a bridge too and I wouldnt have been surprised if I sent it flying off the bridge. Lucky, the 1500 is a solid steel tank and I didnt get as much as a dent on my bumper.
#9 ·
Thanks again everyone. Took my son to the doctor (flu) and the drive went well. Alignment and tracking still seem perfect. No noises or odd behavior. Put it up on ramps when I got home and the attached is the only evidence I can find: a piece of the spanish moss hooked under the rear bumper cover. There were some scrapes on the front bellypan but I couldn't swear what is new and what is from previous minor bottoming-out incidents. They're all minor but I did remove the bellypan and inspected above it and all looks fine. Couldn't even find any debris or bark type scrapes on the rear diff cover which looks like it's the lowest point. So I guess I'm gonna call myself lucky on this one! I even checked the push pins on the rear bumper cover thinking it might have bent something if it hit up under the rear bumper cover. All looks good.
Either I just got lucky or these things are tougher underneath than their thin sheet metal panels on the outside would suggest.
Mike
#10 ·
it probably rolled after the initial hit and thumped on the front cradle, floorpan, trans x-member and rear cradle.
The floorpan steel is stiffer since it supports weight of seats, passengers and cargo and is a key structural member.
