I want to get a camshaft and on multiple websites they have the same cam but have N/A or SC. I am currently N/A but plan to supercharge in the future, so should I get one that says SC or get an N/A one.
The factory cam profile has no impact on the design and application of the aftermarket supercharger, aside from any canned tune they may provide.I cannot speak for all the supercharger kits, but the Magnuson is specifically designed to be installed on a stock engine, and it is those parameters that they can give such good warranty. If you are seriously considering supercharging you need to investigate into that. For the record the Magnuson works extremely well on a stock 5.7 cam. Ry
@lieu910 The quote below is just a part of what Magnuson will discard the warranty regarding, that was my point.I cannot speak for all the supercharger kits, but the Magnuson is specifically designed to be installed on a stock engine, and it is those parameters that they can give such good warranty. If you are seriously considering supercharging you need to investigate into that.
Magnuson sticks their neck out to cover the additional 3 year warranty based on it going on a stock engine. But anyone can toss the warranty out the window and do whatever you want.ALL COVERAGE WILL BE DENIED IF THE DAMAGE TO THE SUPERCHARGER SYSTEM
IS RELATED TO OR ARISES FROM OR OCCURS DURING NON-INTENDED USE, INCLUDING THE:
Use in an application that is inconsistent with the stated catalog application
Use of any components or assemblies that are modified from or substituted for original items, e.g., drive pulleys, fuel injectors
Use of incorrect or contaminated fluids
Use of engine modifications, e.g., oversize crank pulley, aftermarket camshaft, etc.
Use of methanol, alcohol, or nitrous oxide systems
Use of the vehicle in any form of racing or for performance competition purposes
Use of fuel with octane rating less than 91 octane ((r+m)/2 method)
