So what are the chances of this happening to your car? Also is there anything we can do to prevent his from happening . I don’t need these headaches, it scares me that we have a time bomb waiting to happen
There are certain year models which experienced this issue more than others, 2011-2016 being the bulk of them I believe. If your car is within this range, your chances are higher than if it were outside this range.
There aren’t many preventative measures that can be taken to prevent it over and above the normal measures you should always take for any engine.
Don’t run extended oil change intervals (5K miles for conventional is fine and 7500-10000 for synthetic should be good), and don’t idle the engine excessively.
By excessive I mean for 30 minutes to an hour at a time, not the typical idling found in stop and go traffic or drive-thru wait lines. If the engine spends 50% or more of its running time idling, that’s too much and greatly ups the odds you could have this failure.
Running some UOAs every now and again could help spot a failure in the works, but it also may happen so quickly that a UOA wouldn’t have caught it.
There is no set mileage after which this is more likely to occur. For regularly driven cars, the failure usually occurs around the 100K mile mark, give or take 25K miles. But for rarely driven cars, it could happen before they clock 25K miles.
I have 2 cop Chargers, both of which experienced this failure. The 2012 got a new cam and lifters at 90K miles, and I got the car at 100K miles. It now has 226K miles on it and still running strong.
The 2014 got a new cam and lifters at 75K miles, and I got it at 90K miles. It now has 130K miles and still going strong.
Both cars had over 50% of their engine hours clocked idling when I got them, with the 2014 having over 60% of its life spent idling. That tracks with what I’ve seen on the cop Chargers I’ve looked at in auctions - almost all had the failure and all spent excessive time idling.
The only cop Chargers with Hemi’s that I looked at that hadn’t experienced the cam failure were the pre-2011 models. (But those had their own issues, mostly with dropped valve seats)
