just finished installing our getrag dif in our 2010 rt the rear was out of an 09 rt 6 speedcar 3.92s and an lsd. we bought the axles new from dodge as well as the driveshaft coupler and the pink bolts totaling around $450 bucks or so. took us about 4 hours to do the swap but if i could make one recommendation to make the swap alot easier it would be to drill two holes in the spare tire well to access the mounting bolts on the dif. that would make it so that you dont have to lower the rear subframe, we didnt do it but if i was to do it again i def. would. the cars drivablity is much better then it was and the converter works excellent with it. hoping to pick up a .5 or so at the track but hopefully i will be able to get some new track times next week.
